drtkrw Posted November 17, 2009 Share Posted November 17, 2009 Our 2008 Expedition EL is staying locked in the park position because the brake lights are not receiving a singal. Upon further investigation is seems the brake pedal needs to be pulled forward to get the signal to work (this solution is not always 100% effective on the first try). Vehicle now has 37k miles so it is out of warranty (go figure). Has anybody experienced something like this or can recommend a fix? Thanks. Quote Link to comment Share on other sites More sharing options...
akirby Posted November 17, 2009 Share Posted November 17, 2009 Our 2008 Expedition EL is staying locked in the park position because the brake lights are not receiving a singal. Upon further investigation is seems the brake pedal needs to be pulled forward to get the signal to work (this solution is not always 100% effective on the first try). Vehicle now has 37k miles so it is out of warranty (go figure). Has anybody experienced something like this or can recommend a fix? Thanks. There should be a switch attached to the brake pedal that activates the brake lights and disables the brake shift interlock. Quote Link to comment Share on other sites More sharing options...
