ems Posted April 17, 2013 Share Posted April 17, 2013 I have a 98 Navigator with the air suspension and my driver side rear is sagging. It goes up a little but will not go up all the way up. Can anyone advise me if the air bag is an air bag problem or what else should I look for. Are their any tests I can perform to check the problem. Quote Link to comment Share on other sites More sharing options...
woodrowwilson Posted April 17, 2013 Share Posted April 17, 2013 (edited) Could be an air bag leak. Probably is an air leak. Do you hear the motor run that pressurizes the bags? Do you get a warning on the dash about checking the air suspension? If those are original bags they're probably shot. We recently replaced the air ride suspension in the back of my wife's CV with coil springs as it was much cheaper. Change the background color on the page: http://www.crownvic.net/drock96marquis/RAS.htm I know that it's a CV, but it can't be too different I wouldn't think Edited April 17, 2013 by woodrowwilson Quote Link to comment Share on other sites More sharing options...
ems Posted April 17, 2013 Author Share Posted April 17, 2013 Thanks woodrowwilson. I don't get any warning lights at all. The strange thing is that all of a sudden the truck just went back to normal height after being several days low on the drivers side. It seems to be fine now but I know they are going bad. I am going to keep a close eye on them. Quote Link to comment Share on other sites More sharing options...
woodrowwilson Posted April 18, 2013 Share Posted April 18, 2013 If you're not getting the warning indication it probably means your suspension is getting into the proper ride height sensor range before the timeout period is over. That would still likely indicate a leak in one of more of the air struts. Quote Link to comment Share on other sites More sharing options...
