jkes55 Posted April 18, 2013 Share Posted April 18, 2013 I would prefer the intelligent access option most of the time by keeping my key in my pocket but if I'm in a situation where I don't want to take my key with me (no pockets), will intelligent access allow me to lock the key in the car and simply use the keypad to get back in? Quote Link to comment Share on other sites More sharing options...
Camride Posted April 18, 2013 Share Posted April 18, 2013 I believe so but I'm not 100% sure. It's something I have been meaning to try but hadn't gotten around to it. I do know that if you leave the car running and take the key with you the car honks at you, which is really annoying. If three is any way to turn that "feature" off I'd be very happy. Quote Link to comment Share on other sites More sharing options...
jared6788 Posted April 18, 2013 Share Posted April 18, 2013 Yes, you can intentionally lock your key in the car. When you electronically lock your vehicleusing the driver or passenger power door lock control (with any door open, vehicle in park and ignition off), the vehicle will search for an intelligent access key in the passenger compartment after you close the last door. If your vehicle finds a key, all of the doors will immediately unlock and the horn will sound twice, indicating that a key is inside. You can override the smart unlock feature and intentionally lock the intelligent access key inside your vehicle. To do this, lock your vehicle after all doors are closed by: • using the keyless entry keypad • pressing the lock button on another intelligent access key • touching the locking area on the handle with another intelligent access key in your hand. When you open one of the front doors and lock your vehicle using the power door lock control, all doors will lock then unlock if: • the ignition is on, or • the ignition is off and your vehicle is not in P. Quote Link to comment Share on other sites More sharing options...
jkes55 Posted April 18, 2013 Author Share Posted April 18, 2013 Yes, you can intentionally lock your key in the car. Great, thanks for the info. Quote Link to comment Share on other sites More sharing options...
Bearcats98 Posted April 19, 2013 Share Posted April 19, 2013 If you do this, I would take advantage of programming another number into the system other than using the factory number. That way you can cycle the number for security reasons. Its easy as I have already done it. I would not use the factory number in public as it does not appear you can remove it and its always active. Quote Link to comment Share on other sites More sharing options...
