MichaelD Posted June 12, 2017 Share Posted June 12, 2017 Still learning about our new MKC. Today I wanted to program a personal code into the keyless entry keypad. I've read the manual, and understood the instructions, but I can't even get to the programming because the keypad doesn't light up when I touch it. I'm thinking I must be missing something. Is there some setting inside the vehicle that activates/deactivates this function? The manual says that the keypad is invisible until touched. Mine doesn't light up when I touch it. It DOES light up when I have the key fob close-by and then touch the door handle. But when I don't have the key fob, there's no response or lighting up when I touch the pad. When I've got the fob and the pad lights up, it doesn't seem to respond to number presses. Any thoughts on what I'm missing? Thanks. Quote Link to comment Share on other sites More sharing options...
murphy62 Posted June 13, 2017 Share Posted June 13, 2017 That is not the way my Fusion works. I often lock and unlock the car using the keypad when the fobs are well out of range of the car. Touching the keypad causes it to light up. Quote Link to comment Share on other sites More sharing options...
