Panteradon Posted April 4, 2018 Share Posted April 4, 2018 The ABS light on my edge is on intermittently. This morning it was cold out and the light was out. When it warmed back up in the afternoon the light came back on. Dealer says I need new ABS control module and ABD pump at a cost of nearly $4000. My question is where is the ABS control module and ABS pump. I am hoping it is a connection problem and I wanted to remove connection clean and use dielectric grease to see if that help. Don Quote Link to comment Share on other sites More sharing options...
campingnut Posted April 4, 2018 Share Posted April 4, 2018 Not sure on the Edge but usually they are mounted together close to the master cylinder. The bad news is chances are that it is not a connection problem but you can try it never hurts. Quote Link to comment Share on other sites More sharing options...
Panteradon Posted April 5, 2018 Author Share Posted April 5, 2018 Thanks!!! Quote Link to comment Share on other sites More sharing options...
