None
armanmal
Climate control issue with heating
I have trouble with the 2014 SEL FWD 3.5l engine ford edge.
The issue is hot air will start automatically on and blowing around the windshield area. No matter if AC is on or off it will start working irrationally, it will be working for a couple of minutes, sometimes more than 10 minutes then turns off automatically, then again turns on and off. During that issue when I turn AC on, nothing happens, the warm air will still blow around the windshield area. When it turns off by itself I am able to control the AC. I have heard this issue could be somehow associated with blend door actuator.
Any idea about this?
I had a similar problem with my 2014 Limited.  Hot air on the right side of the cabin, cool to the left (driver).  Had to have it fixed at the dealer.  $122 parts.  $304 labor.
Try a HVAC module reset first.
Press the climate control button, defrost button and power button at the same time. Then press the climate control button again within 3 seconds and it will go into a diagnostics mode and reset
