None
skidlm
Miles to empty issue
Hello recently after flat towing a 2020 Ford Fusion se hybrid the miles to empty gauge on the dash reads 999. I can find no way to reset or change it. What happened and can someone help me reset or fix? Thanks
Hi skidlm. Did you check your Owners Manual to see if it can be manually reset in the Drivers Information Center?
If you checked and it can not be manually reset, don't worry, as it will reset itself. The "Miles to Empty" readout uses a running average of the previous ~500 miles to perform its calculations.  So it will recalculate as you drive the vehicle and are using fuel again.
Alternately, you may be able to reset it by disconnecting the battery. However, i would advise against that, as you will lose some other memorized functions (including some engine/transmission parameter memory). Then you will need to perform other procedures to re-establish them.
My opinion: If it can not be reset in the Drivers Information Center, I would just let it relearn over the next ~500 miles. In the meantime, you can use it to brag to your friends. 🤗
Good luck.
Edited by bbf2530
