Megan Posted September 25, 2021 Share Posted September 25, 2021 2002 Lincoln Navigator just stopped starting. Ive had a mechanic hook it up to read the electrical stuff and nothing. No spark to the coils and fuel pump kicks on. Battery is new and camshaft sensor also. Plz help I’m out of ideas. Full tank of gas and put C foam in regularly Quote Link to comment Share on other sites More sharing options...
Reserve471 Posted September 27, 2021 Share Posted September 27, 2021 On 9/25/2021 at 3:46 PM, Megan said: 2002 Lincoln Navigator just stopped starting. Ive had a mechanic hook it up to read the electrical stuff and nothing. No spark to the coils and fuel pump kicks on. Battery is new and camshaft sensor also. Plz help I’m out of ideas. Full tank of gas and put C foam in regularly I'm assuming the car is turning over, but is not starting. If there is no spark to the coils, I would suspect it might be the ECM (electronic control module). These do fail - but before you replace it, check to make sure the unit has a solid ground and that none of the connectors came loose or have corrosion issues. I'd particularly be looking for a solid ground connection. If there were any symptoms prior to this incident (hard start, sputtering, etc., that might be further evidence the ECM was failing). Quote Link to comment Share on other sites More sharing options...
