Intermittent Whistling noise
2011BlueFlame
Hey! This will be my first post but I have been a member for a few months while I was looking for a truck.
With that said, I did find a 2011 F-150, 5.0L, long box and I have noticed an intermittent high pitched whistling noise, but it only occurs while at highway speeds. It sounds like it is coming from the dash area and it noticeable once above 60mph. It is not constant and there is no discernable pattern.
I have done some research but have not found the cause of it yet. Has anyone experienced this before? I have a video but have not uploaded it yet. I figured I would reach out first and see if anyone has experienced this before.
Edited by 2011BlueFlame
On 11/24/2022 at 11:28 AM, Going_Going_Gone said:
Off the wall comment, does the whistle change in tone as you accelerate or decelerate...or does the airflow switch from dash vents to defrost vents w/o you doing anything?  If so, it may be a vacuum leak to the blend door or thereabouts.
 None of the above. It changes but is random and does not matter what heater settings it is at or even if the heater is on at all. Also does not change with accelerator.
Funny enough, since this post I have only heard it once briefly.
Thank you for your reply.
