Hisss 99 Posted January 10, 2006 Share Posted January 10, 2006 Well, the heat exchanger for my Vortech Aftercooler set up has begun to leak. I was condsidering trying to have a radiator shop try and fix it but I think it is aluminum which makes is a lot harder to fix. Should I try this this or just order a replacement. It will cost about $295.00 delivered to my door. Opinions?? Hisss 99 B) Quote Link to comment Share on other sites More sharing options...
52merc Posted January 10, 2006 Share Posted January 10, 2006 Go to a shop specializing in diesel truck radiator repairs. Most new diesel trucks use air to air exchangers on the inlet air side and these are usually aluminum construction. They should be able to pressure test the repair, etc. Quote Link to comment Share on other sites More sharing options...
Hisss 99 Posted January 10, 2006 Author Share Posted January 10, 2006 Thanks for the insight, I will check that out for sure. Quote Link to comment Share on other sites More sharing options...
