sammin Posted October 17, 2008 Share Posted October 17, 2008 Hi, Have a question, looking at a Flex with no 2nd row center console from the factory. Does anyone know if the dealer can install the factory console? Not the fridge, just the console. Thanks Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted October 18, 2008 Share Posted October 18, 2008 Hi, Have a question, looking at a Flex with no 2nd row center console from the factory. Does anyone know if the dealer can install the factory console? Not the fridge, just the console. Thanks Hi sammin. :D Yes, a Dealer can order it and install it for you. However, not all Dealers care for that type of "modification" work. Many Dealers prefer sticking to regular maintenance type work. Others will not have problem performing the work you are asking. It all depends on the attitude of the individual Dealership. So you are better off asking ahead of time if it is a prerequisite to purchasing. Something else to consider: If you are at all handy with basic tools, you could do it yourself. It certainly could not be a hard job (without the refrigerator). Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
trimmer Posted November 6, 2008 Share Posted November 6, 2008 I have a SEL and after having it for a week or so now would like to get the second row console with the fridge in it big question is if it is wired for it or not i see that there is a cover between the two sets just not sure what is under the cover or am i stuck with going with the standard console thanks for your help STAP bother Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted November 6, 2008 Share Posted November 6, 2008 I have a SEL and after having it for a week or so now would like to get the second row console with the fridge in it big question is if it is wired for it or not i see that there is a cover between the two sets just not sure what is under the cover or am i stuck with going with the standard console thanks for your help STAP bother Hi trimmer. :D It is not as simple as just bolting the refrigerator console down where the "standard" console is and hooking up a few wires. There are plumbing lines, a second compressor (and maybe condenser, not sure) and a lot of auxiliary components. You are adding a refrigerator and all the necessary components to your car. It is not really an easy modification. It would take a lot of modification, and no small amount of cash. Good luck. :beerchug: Quote Link to comment Share on other sites More sharing options...
