f150 screw vibration?
rstang1999
I'm looking into buying a new f150 screw, but I'm a little worried about the road vibration problem that some owners are reporting. After the run around I got from Ford with the 1999 Cobra I'm being a bit cautious. So a few questions if you own an 04 - 06 screw.
1. Do you have a road vibration problem?
If you do -
A. What bed length?
B. 4WD or 2WD?
C. What brand of tires are on the truck?
D. Did balancing or changing the tires fix the problem?
Thanks-
If you do -
A. What bed length?
B. 4WD or 2WD?
Thanks-
Ihad a 04 fx4 super crew and got the vibration at about 20 ks. Dealer balanced the tires and replace the driveshaft damper ?? . No trouble after that now have 06 with less that 4k on it .Hoping for no trouble with it
  • 4 weeks later...
