GTwannabe Posted December 31, 2011 Share Posted December 31, 2011 So why does this loaded SuperCrew show 17/23? http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin=1FTEW1CMXCFA17589&refid=FV They only rate powertrain combinations. Any 2WD 3.7L F-150 is rated 17-23, regardless of cab config or gearing. Supercrew is ~500lbs heavier than the standard cab. Quote Link to comment Share on other sites More sharing options...
Bryan1 Posted December 31, 2011 Share Posted December 31, 2011 So why does this loaded SuperCrew show 17/23? http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin=1FTEW1CMXCFA17589&refid=FV Exactly. For EB, SuperCrews will get low 20's without even trying. pickuptrucks.com also got 25 mpg at times in a SuperCrew and a hand calculated 23.2 over a long distance. The 23 we quoted is not for EB so a regular V6 can do even better. Add the improvments of the all new 2015 model and you'll be getting very close to 30 mpg. Quote Link to comment Share on other sites More sharing options...
