rbmount Posted May 2, 2012 Share Posted May 2, 2012 I have a '12 focus hatchback with 10k miles on it. I just noticed the rear window is getting scratched in the wiper footprint. The wiper blade is smooth and not dry rotting. Is anyone else having this issue, and if so, does anyone have a cure? At the rate it's scratching, I'll have to get it replaced very soon. Quote Link to comment Share on other sites More sharing options...
mrgdr57 Posted May 2, 2012 Share Posted May 2, 2012 One of the first things I noticed was the alarming amount of heavy grit that rapidly accumulates above the rear wiper blade. I lift and dust under it daily as part of my cleaning routine. The windshield wiper blades are nearly as bad and need the same care. 1 Quote Link to comment Share on other sites More sharing options...
akirby Posted May 2, 2012 Share Posted May 2, 2012 I lift and dust under it daily as part of my cleaning routine. 1 Quote Link to comment Share on other sites More sharing options...
aneekr Posted May 2, 2012 Share Posted May 2, 2012 One of the first things I noticed was the alarming amount of heavy grit that rapidly accumulates above the rear wiper blade. I lift and dust under it daily as part of my cleaning routine. The windshield wiper blades are nearly as bad and need the same care. +1 Very smart, mrgdr57. :yup: Do you use a rubbing alcohol based solution on a regular basis to clean the wiper blades? rbmount - in addition to a simple daily cleaning routine like mrgdr57 described, for surface prep use a clay bar to remove embedded contamination from the glass, and follow up with an application of Klasse All-in-One. I've done this on all non-porous surfaces on my family's cars, including glass, with much success. Quote Link to comment Share on other sites More sharing options...
mrgdr57 Posted May 3, 2012 Share Posted May 3, 2012 I am admittedly afflicted with OCD. lol Quote Link to comment Share on other sites More sharing options...
mrgdr57 Posted May 3, 2012 Share Posted May 3, 2012 +1 Very smart, mrgdr57. :yup: Do you use a rubbing alcohol based solution on a regular basis to clean the wiper blades? rbmount - in addition to a simple daily cleaning routine like mrgdr57 described, for surface prep use a clay bar to remove embedded contamination from the glass, and follow up with an application of Klasse All-in-One. I've done this on all non-porous surfaces on my family's cars, including glass, with much success. Actually, I have a bottle of Prestone wiper blade cleaner and conditioner with a slotted sponge that I've been using for years. Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted May 3, 2012 Share Posted May 3, 2012 I would also suggest using some sort of Rain-X type product to reduce the need to use the wiper as much in the first place. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 3, 2012 Share Posted May 3, 2012 I am admittedly afflicted with OCD. lol So am I. So am I. So am I. Quote Link to comment Share on other sites More sharing options...
mrgdr57 Posted May 3, 2012 Share Posted May 3, 2012 So am I. So am I. So am I. That must be why we've always gotten along so well. <grin> Quote Link to comment Share on other sites More sharing options...
akirby Posted May 3, 2012 Share Posted May 3, 2012 That must be why we've always gotten along so well. <grin> You have a 2000 LS V8 Sport. I had a 2000 LS V8 Sport. You have a 2012 Focus 5 door. I bought my daughter a 2012 Focus 5 door (2 actually). You're in California..............2 out of 3 ain't bad! Quote Link to comment Share on other sites More sharing options...
