obsidianspider Posted July 30, 2006 Share Posted July 30, 2006 I was looking into putting aftermarket wheels on my 2007 Mustang, but I read in the owners manual that there are tire pressure monitoring system sensors inside the wheels from Ford. Where would I be able to get new tire pressure sensor bands for the new wheels and how much would they cost? Thanks! Quote Link to comment Share on other sites More sharing options...
kevinb120 Posted July 31, 2006 Share Posted July 31, 2006 (edited) Typically there are two types of systems, either the valve stem type(like on expedition) that sends a signal to a sensor on the frame(and can tell you what wheel is low), or the ABS computer can be programmed to notice a wheel that is spinning slower then the others(most likely) that has no hardware involved(but can not tell you what tire is low, ala Windstars have this system). The tire/wheel storeshave surely delt with both types before. Edited July 31, 2006 by kevinb120 Quote Link to comment Share on other sites More sharing options...
obsidianspider Posted August 1, 2006 Author Share Posted August 1, 2006 Typically there are two types of systems, either the valve stem type(like on expedition) that sends a signal to a sensor on the frame(and can tell you what wheel is low), or the ABS computer can be programmed to notice a wheel that is spinning slower then the others(most likely) that has no hardware involved(but can not tell you what tire is low, ala Windstars have this system). The tire/wheel storeshave surely delt with both types before. In the owners manual it shows a band inside the tire, strapped to the wheel, with a sensor that is opposite the valve stem. Quote Link to comment Share on other sites More sharing options...
jay00f4 Posted August 30, 2006 Share Posted August 30, 2006 First generation monitoring systems used bands. The new mustang is using bands, that doesn't mean you can't get bigger bands when changing your wheels or even change them to the valve stem type. Any goor tire shop knows this and will have what you need. Quote Link to comment Share on other sites More sharing options...
