jdircksen
Mystery chimes and warning on 2011 MKZ Hybrid
Hi there,
I am hoping for some technical help on my 2011 MKZ Hybrid. I bought it certified used 9 months ago and had the first oil change (at Lincoln) last week. Coinciding with the oil change has been the arrival of warmer weather here (80+ degrees some days). I am getting very infrequent mystery chimes from the instrument panel. Here is what is happening:
4 chimes - ding dong, ding dong
1 out of 5 times a red message flashes (literally a split second) over the temperature gauge. Most of the time I just get chimes but nothing else. Just ding dong, ding dong out of no where. However I did catch the message one - "High Engine Temperature".
Most of the time it happens during a slow turn but sometimes happens while driving straight.
Sometimes I get the chimes shortly after starting the car
If it is temperature related, I did read something about air bubbles in the coolant. I'll keep exploring that route.
Any other thoughts?
Thanks!
Edited by jdircksen
I took video of the issue. The volume is a bit low so turn up your speakers. Hopefully this works:
And Lincoln can't get me in for another 2 weeks so hopefully we find out what the issue is.
Edited by jdircksen
Did you figure out the problem mine is doing the same thing
The issue ended up being related to a loose wiring harness just like expresspotato thought.  If I remember correctly, it was a wiring harness on the transmission.  I remember the tech saying the wires were loose in the plug and had to be re-soldered.
