gogi Posted February 12, 2018 Share Posted February 12, 2018 1FAFP 31N06W234992 ok im in deep doo doo.just purchased this car and am already into it for $ 1167 not counting purchase price. new spark units mass airflow sensor new map sensor 2 motor mounts 4 spark plugs and new intake.the car runs good per mechanic who i trust using him for 30 years.the problenm started with miss on # 2 cylinder.replaced 4 plugs and 4 spark units.car began to run like crap,backfire terrible,code for maf came up replaced that.started again horrible backfiring and then big bang.blew the bottom of intake manifold by #2.replaced manifold still not running right.code for map sensor.replaced that.car running well. check engine light on.map sensor.found the computer reading from red wire 40 below zero. HELP! Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted February 12, 2018 Share Posted February 12, 2018 Whats the maf code you are getting? Is it p0171 lean codes ? Also is he checking barometric pressure pid and it reading way off? Clogged catalytic converter can cause a maf to read crazy. Quote Link to comment Share on other sites More sharing options...
gogi Posted February 13, 2018 Author Share Posted February 13, 2018 (edited) WILL HAVE TO TALK TO MECHANIC I WOULD THINK ITS 113 CODE FOR MINUS 40 DEGREE READ.DOUBT CAT AS CAR IS NOT SLUGGISH NO LOSS OD POWER NO SULFER SMELL ALSO PASSENGER AIR BAG LIGHT IS ON TOO Edited February 13, 2018 by gogi Quote Link to comment Share on other sites More sharing options...
