stretches flex Posted September 26, 2018 Share Posted September 26, 2018 (edited) help I checked the fuse, it seems ok, did not see a fuse inside the car just the one under the hood Edited September 26, 2018 by stretches flex Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 26, 2018 Share Posted September 26, 2018 We need a little more info. Year? Is it manual ac or automatic temp control. Quote Link to comment Share on other sites More sharing options...
stretches flex Posted September 26, 2018 Author Share Posted September 26, 2018 2010 , auto temp control Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 26, 2018 Share Posted September 26, 2018 Check fuse 35 under the hood. What I would do First is disconnect the connector to blower motor. Put a test light or use a tail lamp bulb and use that as the load and see if they illuminate when you turn blower on high. If not, without proper diag I would guess at a blower speed controller. Does the ac control head light up and seem to respond? Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 26, 2018 Share Posted September 26, 2018 If you have a test light, check for power on yellow and green wire at two pin blower motor connector with key on. If no power then we need to look back at fuses and relays. If you have power do what I recommend with the light bulb in blower motor connector to substitute the blower with a bulb. That will check power and ground. If it illuminates then the motor is bad. Quote Link to comment Share on other sites More sharing options...
stretches flex Posted September 27, 2018 Author Share Posted September 27, 2018 Don't know how but fuse 35 wasn't even there, I did hit a big bump and must have knocked it out. I don't know where it went, or how it escaped from the fuse box but I replaced it and all is ok now. Thanks for your imput... Quote Link to comment Share on other sites More sharing options...
fordtech1 Posted September 27, 2018 Share Posted September 27, 2018 Most of the time people take fuses out to replace a blown fuse for a power point. Glad it was easy. Quote Link to comment Share on other sites More sharing options...
Going_Going_Gone Posted October 13, 2018 Share Posted October 13, 2018 Isn't the help on this forum great? Quote Link to comment Share on other sites More sharing options...
