Jmanga85
Alarm goes off randomly
For a little while I've been chasing an alarm issue. It will go off within a few minutes of locking the vehicle. With a scan tool hooked up I can see past alarm triggers for the decklid. Knowing ford and their problem of bad door switches/latches I replaced the trunk closed switch. So......that didnt work. It has a power decklid so there is a possibility the motorized latch that pulls it shut also has a switch to tell the trunk module that it is closed. This part is way more expensive than the other close switch located on the trunk itself. Just wanted to see if anyone out there has had similar issues and a solution to their own problem that might point me in a right direction. Thanks!
