Witchdoc Canada Posted November 9, 2023 Share Posted November 9, 2023 On 1/26/2021 at 7:53 PM, Gidyupgo said: Bullitt6283, I am surprised more people aren't discussing this. Maybe on a different forum? Anyway, 2016 6.8 in a Class C with 41k miles. It's been making this noise since new (4 years) at 2100 rpm. Installed the driver's side idler today. Pulled the air filter for access and easily deflected the belt enough to install. I did not loosen or replace the belt. Inspected it and it looked fine. Leaving tomorrow for a 750 mile trip. Thanks so much. Now my issue Ford parts in Canada shows no bolt #id to hold the pulley on . I gave them that # and nothing popped up ??? any other code that would help parts dept? oh, tried Lordco parts in Canada they have lots of these pulleys , but no bolt to hold it on . Quote Link to comment Share on other sites More sharing options...
Witchdoc Canada Posted November 9, 2023 Share Posted November 9, 2023 7 minutes ago, Witchdoc Canada said: Thanks so much. Now my issue Ford parts in Canada shows no bolt #id to hold the pulley on . I gave them that # and nothing popped up ??? any other code that would help parts dept? oh, tried Lordco parts in Canada they have lots of these pulleys , but no bolt to hold it on . Thank you Bullitt .your info was bang on. installed the items ( 20$ Ford bolt and a 40$ non oem pully ) Can’t test it fully until a March with a trip into states of WA down to ARIZ then back up through Utah , ID. Quote Link to comment Share on other sites More sharing options...
Gidyupgo Posted November 10, 2023 Share Posted November 10, 2023 We've put about 15k miles on it since doing this. No issues, no belt vibration noise. Good fix. Thanks to all that provided research. Ford blew it when they deleted the driver side idler pulley. 1 Quote Link to comment Share on other sites More sharing options...
chromeronzo Posted November 10, 2023 Share Posted November 10, 2023 I have to agree...Ford...trying to save a buck....however, with this fix done to my E-450, I have also had thousands of miles of noise-free enjoyment...thanks again to Bullitt Quote Link to comment Share on other sites More sharing options...
Witchdoc Canada Posted November 14, 2023 Share Posted November 14, 2023 On 10/24/2023 at 8:00 AM, Bullitt6283 said: A quick online search for N808102-S437 shows several sources for this bolt. Here's one: https://www.tascaparts.com/oem-parts/ford-idler-pulley-bolt-n808102s437 . . On 10/26/2023 at 1:25 PM, Bullitt6283 said: If I recall correctly, the idler pulley on the passenger side of the block is the same pulley number and held on with the same bolt. Perhaps a trip to a salvage yard would solve the bolt problem.... .. Quote Link to comment Share on other sites More sharing options...
Witchdoc Canada Posted November 14, 2023 Share Posted November 14, 2023 Yes , you were correct. Bolt from Ford ($20.) and a non OEM pulley installed . Thanks for the continued help ! Quote Link to comment Share on other sites More sharing options...
chromeronzo Posted November 14, 2023 Share Posted November 14, 2023 I ordered the same bolt and pulley as for the driver's side....Ford of Canada is screwing with you Quote Link to comment Share on other sites More sharing options...
