Windshield Washer Pump
Hubcap
I have a 2016 E450. Typical V10 etc. My windshield washer pump does not work. First is there a separate fuse for it somewhere? Every thing else works. Second, I assume the pump is on the tank, but I can't see the tank from anywhere to access it. Anyone done this? Have to remove battery? Inner fender panel? Thanks in advance!
From the diagram (from a 2007, but I am almost sure it is the same on all E-Series) it looks like it is mounted on the passenger side inner fender and the pump itself is located in the side of the tank closest to the fender (of course). From what I see, you will likely have to take the battery out to access it as well as some other disassembly. Good luck. The plus side is, the pump itself is less than $20 on most auto parts stores.
Info found on an RV site..
https://www.irv2.com/forums/f23/2007-ford-e450-washer-motor-problems-291809.html
Good luck.
