Scgamecock Posted February 12, 2022 Share Posted February 12, 2022 I have a 2011 F250 Superduty and the switch isn’t working to extend and retract the mirrors. I have not used them in a while and somehow I must have hit the switch and it got stuck in the depressed position. Now the mirrors don’t work. Is there a fuse to check before pulling the switch? If so where is it located? Thanks! Wade Quote Link to comment Share on other sites More sharing options...
IUEC135ELEVATOR Posted February 13, 2022 Share Posted February 13, 2022 (edited) Is this a metaphor or euphemism? Drop a viagra in the fuel tank....ummmm, yeah! Edited February 13, 2022 by IUEC135ELEVATOR Quote Link to comment Share on other sites More sharing options...
787Toolman Posted February 13, 2022 Share Posted February 13, 2022 3 hours ago, Scgamecock said: I have a 2011 F250 Superduty and the switch isn’t working to extend and retract the mirrors. I have not used them in a while and somehow I must have hit the switch and it got stuck in the depressed position. Now the mirrors don’t work. Is there a fuse to check before pulling the switch? If so where is it located? Thanks! Wade Might try to find a schematic, if the switch is stuck, there is mostly likely a relay, and it would be stuck in extend or retract until you release the switch if my understanding of how it works is accurate. Try the opposite side, if it works, the fuse is probably not the issue as I doubt there is a fuse for each side but I'm guessing. Remove the switch and operate manually using jumper wires, if this is not something you feel comfortable diagnosing, need to take to a shop. Electrical diagnosis takes a good understanding of circuits and trouble shooting skills and sometimes even shops don't know how to properly troubleshoot and end up just being parts replacers. Good luck... 787Toolman 1 Quote Link to comment Share on other sites More sharing options...
787Toolman Posted February 17, 2022 Share Posted February 17, 2022 On 2/12/2022 at 3:58 PM, Scgamecock said: I have a 2011 F250 Superduty and the switch isn’t working to extend and retract the mirrors. I have not used them in a while and somehow I must have hit the switch and it got stuck in the depressed position. Now the mirrors don’t work. Is there a fuse to check before pulling the switch? If so where is it located? Thanks! Wade Wade, See below, this is the mirror extend circuit for a 2017, might be same or similar to yours. Maybe this will help you diagnose your problem, might be different than your design and not help. You can purchase service CDs online that is same as what dealer's use. 787Toolman 1 Quote Link to comment Share on other sites More sharing options...
mattdm Posted February 19, 2022 Share Posted February 19, 2022 my old truck did this. they got mechanically jammed, probably something internal wearing out or just old dried up lubricant. give them a bump with your fist, or better yet have someone hold the switch when you hit them. 1 Quote Link to comment Share on other sites More sharing options...
