Kevin Saunders Posted May 20, 2023 Share Posted May 20, 2023 I have a 2019 F250 Lariat 4wd. It has a 4" lift front 2" lift back. The truck sits 1" lower on the left side naturally. I am trying to find the best of: Airbags Compressor Leveling switches Reserve tank Air chuck for air hose to inflate tires Interior gauges or phone app From what I see, people are mixing brands to get the best results but searching all over presents old or confusing results. I want to level out the truck and, of course, keep it that way with a load so my headlights are aimed correctly. Thank you in advance for your advice. Quote Link to comment Share on other sites More sharing options...
Boss Hog Posted July 23, 2023 Share Posted July 23, 2023 I’m running Ready Lift AirIQ system with the HD compressor. It’s a dual inline bag and works superb. Being an F350, factory overloads are removed and the air bags mount directly on top of the leaf stack to replace overloads. Empty, I run 10psi and it rides way better than with overloads when hitting bumps or potholes. The jar in the rear is reduced a lot. With the HD compressor, left and right side are independent so 20 psi could be in the right and 30 in the left. It was a pricey system but compared to my AirLift bags I have on my other truck, I’ll go no other way than Ready Lift from this point on. Bluetooth and the compressor is quick to adjust 1 Quote Link to comment Share on other sites More sharing options...
