Sgovind Posted October 2, 2023 Share Posted October 2, 2023 Hi all, I am new to the forum. I have a 2008 Ford Escape V6 4WD. I'm hearing / feeling a rumble noise at 50 to 60 km/hr. Its still there past 60. But not resonating or very disturbing. Driving on streets causes a headache as 50-60 is the speed driven most. Also, the sound gets loud while turning left. Checked all 4 wheel bearings. Does seem fine except for slight brake rubbing on rear. What could be the problem? Also, I tried swapping the wheels with my winter wheels.. sound is still present. Accelerating or decelerating does not make a difference. Changed diff fluid too without luck. The car always had a drivetrain kinda noise like gears meshing from the rear, but not at all disturbing. I thought that would be natural to 4wd. Quote Link to comment Share on other sites More sharing options...
akirby Posted October 2, 2023 Share Posted October 2, 2023 Could still be a wheel bearing or a CV joint. 1 Quote Link to comment Share on other sites More sharing options...
Sgovind Posted October 3, 2023 Author Share Posted October 3, 2023 It is the wheel bearing. Checked with the mechanic. The sound I mentioned as brake shoes rubbing were actually the bearings grinding. No play.. but it may start wobbling soon if not changed. Thanks! Quote Link to comment Share on other sites More sharing options...
