Aviator high tire pressures still valid?
gbgastowers
On 11/9/2024 at 9:12 AM, gbgastowers said:
The tire pressures listed on the door jam sticker seems a bit excessive. Does anyone know if they are still accurate? What are the pressures listed on the newer ones? Mine is a 2020 and it says 42 rear and 38 front I believe. Gunar
Just curious why you think the tire pressures are excessive?  Your tires are probably not 75 or 80 series that have 5 inches of sidewall to flex.  Manufacturer tire pressures are set to balance ride comfort, tread life, and load capability.  You need a certain amount of minimum pressure to maintain sidewall integrity, especially in low profile tires.  You also need certain pressure to maintain a flat contact patch for even tread wear.  Best fuel economy is achieved at higher pressures (for lower contact patch) but decreases ride quality.  You are free to set whatever pressure you want, but don't be surprised if you have decreased fuel economy, see excessive wear on your tire shoulders, or potentially have a blowout.
  • 3 weeks later...
  • 1 year later...
My 26 with 22 inch wheels are 36F / 39R.  The 40 series tires don't provide a decent ride quality so I have 19 inch Aviator wheels on order, I'll mount P265/55R19 tires on them which should provide a more comfortable ride quality.  The brakes are 15 inches wide so you could put a 17 inch wheel on the Aviator without a fitment issue, just watch your offset.
