08 Focus Question
Stus1171
I just picked up my new 08 Focus SES (ordered in February) today. It's Vista Blue, black leather, and a 5 speed. My wife has a 08 Focus SES automatic, so I knew it would be a great car. I do have a question though. My wife's has the autolock/unlock feature, but my car does not. I wasn't sure if it is because of the difference in transmission, or if it was left off as an oversight from the factory.
Thanks!
Edited by Stus1171
that was from the old focus'. i guess it isnt the same.
but this is from the owners manual of the 08 focus.
to enable autolock(if equiped)
1. using the setup button scroll to the autolock screen in message center.
2. use reset button to pick between on/off
to enable auto-unlock
1. using the setup button scroll to the auto-unlock screen in message center.
http://www.motorcraftservice.com/pubs/cont...0/08focog1e.pdf
pages 58-59
this is the other option they list: page 63
Power door unlock/lock procedure
Before starting, ensure the ignition
is in the 1 (LOCK) position and all
vehicle doors are closed. You must
complete Steps 1–5 within 30
seconds or the procedure will have
to be repeated. If the procedure
needs to be repeated, wait a
minimum of 30 seconds before
beginning again.
1. Place the key in the ignition and turn the ignition to the 3 (RUN)
position.
2. Press the power door unlock control on the door panel three times.
3. Turn the ignition from the 3 (RUN) position to the 1 (LOCK) position.
4. Press the power door unlock control on the door panel three times.
5. Turn the ignition back to the 3 (RUN) position. The horn will chirp
one time to confirm programming mode has been entered and is active.
6. To enable/disable the autolock feature, press the unlock control, then
press the lock control. The horn will chirp once if autolock was
deactivated or twice (one short and one long chirp) if autolock was
activated.
The instructions forgot the last step that might (probably not though) work:
Turn the ignition to the 1 (OFF/LOCK) position. The horn will chirp
once to confirm the procedure is complete.
Anyway, I do wonder if it has to do with the manual transmission...thought it really shouldn't. I also own one with manual transmission, and it did not come with the autolock on. Of course, I wasn't relaly looking for it, though. My 2008 Mustang and 2007 Mariner have it, and I find it to be more of a nuisance than anything.
the more i think about it, it probably is because of the tranny. the locks unlock when put into a non-moving gear(park) a 5 speed doesnt technically have one and it would be hard for the computer in the car to know what gear it was in.
its probably another one of those things you cant get on 5spd to protect the company. like remote start
That's what I was thinking.
"I just picked up my new 08 Focus SES (ordered in February)"
I ordered an 08 on Jan 25th and am still waiting!!!!!!!!
Confirmed delivery is this week but I also heard that back in the first week of March also.
I ordered mine February 16th and it came in on March 21st. I was happy with the delivery time.
I did order mine X-plan, but I doubt that makes a difference in delivery time.
Edited by Stus1171
I just got the call today, the 26th, it has arrived. Maybe this post brought me some luck!!!
