debodav Posted August 12, 2011 Share Posted August 12, 2011 Has any one disabled the skip shift function on the new 6 speed trany? how is it done . thanks David Quote Link to comment Share on other sites More sharing options...
Jewish Santa Posted August 12, 2011 Share Posted August 12, 2011 (edited) Has any one disabled the skip shift function on the new 6 speed trany? how is it done . thanks David There is a thread on this... Its about 8-10 threads down. Try searching first but I'll make it easy for you. Tune it out or try this... http://www.svtperformance.com/forums/how-370/740066-skip-shift-mod-w-o-needing-tune.html Edited August 12, 2011 by Jewish Santa Quote Link to comment Share on other sites More sharing options...
debodav Posted August 12, 2011 Author Share Posted August 12, 2011 There is a thread on this... Its about 8-10 threads down. Try searching first but I'll make it easy for you. Tune it out or try this... http://www.svtperformance.com/forums/how-370/740066-skip-shift-mod-w-o-needing-tune.html Thanks Quote Link to comment Share on other sites More sharing options...
Gulfstream Posted September 9, 2011 Share Posted September 9, 2011 Has any one disabled the skip shift function on the new 6 speed trany? how is it done . thanks David What is the purpose of the skip shift? Quote Link to comment Share on other sites More sharing options...
akirby Posted September 9, 2011 Share Posted September 9, 2011 What is the purpose of the skip shift? Higher fuel economy on EPA tests. Usually done to avoid a gas guzzler tax. Quote Link to comment Share on other sites More sharing options...
dwh755 Posted September 16, 2011 Share Posted September 16, 2011 For all those concerned about this feature: Here is my experience with my car! I don't know if there have been changes to how the car is set up. AGAIN THIS IS MY EXPERIENCE WITH MY CAR. No I have not put a tuner on my car or disconnected the 1-4 connector on the transmission! On august 30th my 2012 Grabber Blue 6 spd 5.0 was delivered. I currently have a bit under 900 miles on it. During the 2 weeks I have been driving it the 1-4 shift light has come on several times. The first time it came on I thought ok I will play and shifted to 4th. Doing that sucked since it bogged the car down. Since then I NEVER shifted to 4th when the 1-4 shift light comes on. I know that book leads you to believe it "locks" 2nd and 3rd. With my car that is it does NOT LOCK OUT 2nd and 3rd gear. I simply ignore the light and shift the transmission in anyway I want to. Perhaps others should do the same: ignore the prompt and shift normally to see what their cars do. David Quote Link to comment Share on other sites More sharing options...
