casadejj Posted May 14, 2012 Share Posted May 14, 2012 I don't know if this interests anyone, but there is a way to disable the seat belt chime in the Flex: WARNING: While the design allows you to deactivate your Belt-Minder, this system is designed to improve your chances of being safely belted and surviving an accident. We recommend you leave the Belt-Minder system activated for yourself and others who may use the vehicle. To reduce the risk of injury, do not deactivate/activate the Belt-Minder feature while driving the vehicle. 1. Turn the ignition switch to the on position. DO NOT START THE ENGINE. 2. Wait until the safety belt warning light turns off (Approximately one minute). 3. Wait 10 seconds after the safety belt warning light turns off. • Step 4 must be completed within 20 seconds after the completion of Step 3. 4. For the seating position being disabled buckle then unbuckle the safety belt three times at a moderate speed, ending in the unbuckled state. • After Step 4, the safety belt warning light will be turned on for three seconds. 5. Within approximately seven seconds of the light turning off, buckle then unbuckle the safety belt. • This will disable the Belt-Minder feature for that seating position if it is currently enabled. As confirmation, the safety belt warning light will flash four times per second for three seconds. • This will enable the Belt-Minder feature for that seating position if it is currently disabled. As confirmation, the safety belt warning light will flash four times per second for three seconds, followed by three seconds with the light off, then followed by the safety belt warning light flashing four times per second for three seconds again. Seating and Safety Restraints Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted May 14, 2012 Share Posted May 14, 2012 Easier way to disable the Belt Minder: put on your seatbelt. Quote Link to comment Share on other sites More sharing options...
akirby Posted May 14, 2012 Share Posted May 14, 2012 Not if you're desperately trying to reach 10 posts to request vehicle tracking..... 1 Quote Link to comment Share on other sites More sharing options...
