redwings1914 Posted December 19, 2012 Share Posted December 19, 2012 I bought some LEDs off of Amazon to swap out on the license plate lights, The passenger side install light went smoothly (less than 5 mins) although now I am having one heck of a time trying to switch the drivers side. The housing simply will not come out/budge. I'm worried I might have made it impossible to remove now while I was trying to pry it out Any advice? Quote Link to comment Share on other sites More sharing options...
twintornados Posted December 19, 2012 Share Posted December 19, 2012 (edited) They are push in clipped into the deck lid....if you are changing the bulb, you shouldn't have to yank the entire housing assembly. If you are yanking the housing, pull down the interior felt covering and reach in to squeeze the side tabs so that the housing comes out. Disconnect the wire harness first from the housing assembly...it will facilitate the housing coming out. EDIT: Sorry...didn't see that you were talking about a 2013....in that case...I don't know for sure, but it looks similar to my 2012 light assembly. Edited December 19, 2012 by twintornados Quote Link to comment Share on other sites More sharing options...
redwings1914 Posted December 20, 2012 Author Share Posted December 20, 2012 Went outside this morning to give it one more try before giving up and taking it in to see if the dealer could pop it out and alas it worked, definitely looks better than the stock bulbs! 1 Quote Link to comment Share on other sites More sharing options...
jinx8402 Posted December 20, 2012 Share Posted December 20, 2012 mind sharing a link with the LED's you used? I will probably want to switch out to LED lights as well. Quote Link to comment Share on other sites More sharing options...
MineralstangGT Posted December 20, 2012 Share Posted December 20, 2012 Went outside this morning to give it one more try before giving up and taking it in to see if the dealer could pop it out and alas it worked, definitely looks better than the stock bulbs! Nice! I have led bulbs on the rear plate of my mustang. Definitely better. Can we see pics of the car? Details on the car? Quote Link to comment Share on other sites More sharing options...
redwings1914 Posted December 20, 2012 Author Share Posted December 20, 2012 mind sharing a link with the LED's you used? I will probably want to switch out to LED lights as well. http://www.amazon.com/2pcs-20-SMD-Light-Replacement-Bulbs/dp/B006R34PB4/ref=sr_1_4?ie=UTF8&qid=1356036277&sr=8-4&keywords=led+w5w Here's mine, arrived in 2 days! Quote Link to comment Share on other sites More sharing options...
redwings1914 Posted December 20, 2012 Author Share Posted December 20, 2012 Nice! I have led bulbs on the rear plate of my mustang. Definitely better. Can we see pics of the car? Details on the car? I'll get some pics up once this "death storm" (aka rain-fest) passes over Quote Link to comment Share on other sites More sharing options...
vincep5 Posted December 24, 2012 Share Posted December 24, 2012 How do you open the plastic cover? It looks similar to the puddle lamps under the side mirrors. I don't want to break the plastic with a screwdriver. Quote Link to comment Share on other sites More sharing options...
redwings1914 Posted December 25, 2012 Author Share Posted December 25, 2012 How do you open the plastic cover? It looks similar to the puddle lamps under the side mirrors. I don't want to break the plastic with a screwdriver. Take a screwdriver and slide over the tab on the right side of the light, it might take some elbow grease. Don't worry, if I didn't break it I don't think anyone will, I nearly snapped the screwdriver in two trying to open it initially 1 Quote Link to comment Share on other sites More sharing options...
vincep5 Posted January 5, 2013 Share Posted January 5, 2013 I replaced mine with similar led bulbs. It was pretty easy and it looks great. Thanks for the info Quote Link to comment Share on other sites More sharing options...
c.blackfoot Posted January 6, 2013 Share Posted January 6, 2013 Has anyone replaced the bulbs under the side view mirrors to LEDs? Quote Link to comment Share on other sites More sharing options...
BrightLites Posted June 17, 2014 Share Posted June 17, 2014 I know this is an old thread, but our company, DAYTIME BrightLites and webstore www.DriveBright.com offers a totally plug and play direct replacement LED Puddle Light for all Ford & Lincoln vehicles with the mirror puddle light feature. Our LED Puddle Light pack includes two upgraded LED puddle lights and two bright white LEDs to replace the bulbs in the license plate lamps. We also carry several other LED lighting products made specifically for certain models, such as LED daytime running lights, LED taillights, interior and exterior model specific LED packages and high quality HID headlight replacement kits. Check them out by clicking on the image below. Quote Link to comment Share on other sites More sharing options...
