1999 White C5 Coupe Posted March 20, 2015 Share Posted March 20, 2015 (edited) The Limited comes with All Season tires standard, not All terrain tires. Your salesman was wrong. The printed order guide he provided me showed the Limited 4 x 4 standard wheels are 20" Polished Aluminum Wheels (first picture above) with 275/55R20 AT BSW tires. The rear-wheel drive model gets 275/55R20 AS BSW tires standard. The picture above shows the all terrain tires on the 20" polished wheel. The XLT model has 18" wheels and tires standard, but I did not want the XLT model. The first wheel pictured above is the wheel that was on other Limited 4 x 4 models on the lot and had the all terrain tires. The dealership did not have any rear-wheel drive models in stock, but he said the guide showed those models received all season tires. Since the wheel and tire sizes are identical, I didn't understand why he was not permitted to order the all season tires on the 4 x 4 model. Edited March 20, 2015 by 1999 White C5 Coupe Quote Link to comment Share on other sites More sharing options...
akirby Posted March 21, 2015 Share Posted March 21, 2015 Strange - that is what the order guide shows but not what is currently on the website. I checked a window sticker and it doesn't say either way. Quote Link to comment Share on other sites More sharing options...
flafordtrucks Posted August 25, 2015 Share Posted August 25, 2015 I recently purchased a 2015 Expedition EL 4x4 with Hancook DynaPro ATM 275/55/20 tires. Door placard says to run 35psi. At 35psi they look low. Ford servince manager said they look low "but that is what Ford calls for". I contacted Hankook tech support and they said run 90% of max pressure = 45.9psi. (Max is 51psi) In the Florida heat i do not what to be under inflated. I am a 50/50 city/highway driver. Does anyone have experience with these tires on this vehicle and can you recommend a safe tire pressure? Thanks in advance Quote Link to comment Share on other sites More sharing options...
