it wants to run as if it is on cruise but its not. something will happen and it goes back to normal   help
You mean the engine is running but your car will not move?
If you mean it’s accelerating when you’re not touching the pedal it could be the pedal assembly or the throttle body.
Posted (edited)
thank you kirby it runs fine but you don't have to use the pedal(like its on cruise), sometimes it gains speed and sometimes something turns on or off and it all goes back to normal.been chasing this for a while. it has trouble downshifting and will stall when brought to a stop. cleaned throttle body, maf,air cleaner, replaced iac and pcv. still same problem. it's got me so far
Edited by wayne porter
spelling
it runs fine.takes off and gets to speed but when you let off the pedal lt doesn't deselerate. acts as on cruise. then it won't downshift right and will stall when stopped. refires right away. got me so far. any ideas?
Sounds like the throttle body is bad.
