chicken Posted August 30, 2022 Share Posted August 30, 2022 We recently received our 2022 reserve navigator to replace our 2019 model due to ongoing issues with it. One thing I noticed in the 2022 is the AC is very different compared to our 2019. We live outside of SF and it gets really hot during the summer with temps peaking over 100+ With the 2019 navigator we never had to use the max cold button on the AC. We would set it around 65 and it kept the inside of the vehicle perfect. This new navigator if we set it to 65 it pretty much turns the air to the lowest setting and barely blows any air. If I keep lowering the temp the speed does not change, unlike our 2019. Not until I get to 60 degrees does it speed up somewhat. When I set it to low it speeds up a little more but does not really keep the car that cool when it super hot out. If I hit max cold it gets slightly cooler but only seems to be running like 2/3 the speed of max on our 2019. I am curious if anyone else has a 2022 sees similar AC behavior? I am going to make a service appointment to take it it but this almost seems like a software issue. Thanks! Quote Link to comment Share on other sites More sharing options...
HofstraJet Posted August 30, 2022 Share Posted August 30, 2022 (edited) Something is definitely amiss. I am in South Florida and my AC works year round and I’ve never experienced that. Recently had the evaporator die (at the start of a long road trip, naturally). In my experience, the thermostat just indicates at what temperature the air comes out based on the current temperature and also controls the fan speed when set to auto. I believe all Max Cold does is turn the fan on high, temperature to Lo, and turn on cabin air recirculating. Have it checked out. Edited August 30, 2022 by HofstraJet Quote Link to comment Share on other sites More sharing options...
chicken Posted September 3, 2022 Author Share Posted September 3, 2022 On 8/30/2022 at 8:23 AM, HofstraJet said: Something is definitely amiss. I am in South Florida and my AC works year round and I’ve never experienced that. Recently had the evaporator die (at the start of a long road trip, naturally). In my experience, the thermostat just indicates at what temperature the air comes out based on the current temperature and also controls the fan speed when set to auto. I believe all Max Cold does is turn the fan on high, temperature to Lo, and turn on cabin air recirculating. Have it checked out. I have an appointment next week. It would have been 4 weeks if I wanted a loaner vehicle though ?. Is that something you guys are a lot? If you want a loaner while they do work it’s X weeks out vs if you don’t its next week? Thx Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted September 3, 2022 Share Posted September 3, 2022 (edited) On 8/30/2022 at 11:09 AM, chicken said: We recently received our 2022 reserve navigator to replace our 2019 model due to ongoing issues with it. One thing I noticed in the 2022 is the AC is very different compared to our 2019. We live outside of SF and it gets really hot during the summer with temps peaking over 100+ With the 2019 navigator we never had to use the max cold button on the AC. We would set it around 65 and it kept the inside of the vehicle perfect. This new navigator if we set it to 65 it pretty much turns the air to the lowest setting and barely blows any air. If I keep lowering the temp the speed does not change, unlike our 2019. Not until I get to 60 degrees does it speed up somewhat. When I set it to low it speeds up a little more but does not really keep the car that cool when it super hot out. If I hit max cold it gets slightly cooler but only seems to be running like 2/3 the speed of max on our 2019. I am curious if anyone else has a 2022 sees similar AC behavior? I am going to make a service appointment to take it it but this almost seems like a software issue. Thanks! Hi chicken. While this is probably not the cause of your low air volume issue, I figured better to play it safe and mention it: If the climate control system settings in your Navigator is similar to my MKZ (I would think it should be), there is a climate control setting to limit the highest allowable fan speed during AUTO AC use. It can be set to limit the system to a low fan speed, allow a medium fan speed, or high (no fan speed limit). If you have it set to low, the AC system will only use a low fan speed while set to AUTO, no matter the temp setting. It will not use a higher airflow setting. The situation you are describing sounds as though it may be a case of the AUTO Fan Speed setting being set to low. So before you bring your vehicle in for service, give it a quick check to be sure you do not have the AUTO fan speed setting set to the low limit. Let us know how you make out and good luck. Edited September 3, 2022 by bbf2530 Quote Link to comment Share on other sites More sharing options...
Black Label Posted September 3, 2022 Share Posted September 3, 2022 You did not mention if you run it in AUTO, but if so, this is what bbf was referring to. You can press the button to go from one to three lines, indicating max fan speed in AUTO. 1 Quote Link to comment Share on other sites More sharing options...
HofstraJet Posted September 3, 2022 Share Posted September 3, 2022 That’s pretty cool (no pun intended). Had no idea that feature existed. ? 1 Quote Link to comment Share on other sites More sharing options...
Black Label Posted September 3, 2022 Share Posted September 3, 2022 1 hour ago, HofstraJet said: That’s pretty cool (no pun intended). Had no idea that feature existed. ? Yes, and I find that running the system in AUTO works best. It takes all the various inputs and adjusts everything accordingly, including keeping the windows from fogging up. In my 2020 and now 2022, I never once have had foggy windows as the system magically does everything. Quote Link to comment Share on other sites More sharing options...
mjandbj Posted September 5, 2022 Share Posted September 5, 2022 Very cool feature! Thanks for the pics. 1 Quote Link to comment Share on other sites More sharing options...
