Dtoom Posted October 20, 2022 Share Posted October 20, 2022 Month old 2022 f250 platinum. Interior map lights started just working every now and then. No illumination on the overhead console buttons except aux switches and back sliding glass when the issue is happening. Dealer has no idea whats going on with it. Any suggestions? Quote Link to comment Share on other sites More sharing options...
le engineer Posted October 20, 2022 Share Posted October 20, 2022 (edited) Take it to another dealer. This is a brand new high dollar truck. Fixing it is Ford’s problem. Edited October 20, 2022 by le engineer Quote Link to comment Share on other sites More sharing options...
sd350 Posted October 21, 2022 Share Posted October 21, 2022 I don't have my new truck yet, but ck the fuses not sure if this is how the new 1 come . on the fuse panel, they have a fuse that's not pushed in until delivered to make sure the battery doesn't go dead while in shipping. If there just make sure that fuse is in tight good to ck that fuses in either case. some of them will have a yellow plastic sleeve around it. Quote Link to comment Share on other sites More sharing options...
IUEC135ELEVATOR Posted October 23, 2022 Share Posted October 23, 2022 (edited) Don't you miss the days of 12v battery to fuse to switch to 12v component? Now it is 12v battery to computer to switch to 5v control modules to components.....meh! (Or something like that) Edited October 23, 2022 by IUEC135ELEVATOR Quote Link to comment Share on other sites More sharing options...
Monoman Posted October 25, 2022 Share Posted October 25, 2022 (edited) On 10/20/2022 at 7:55 AM, Dtoom said: Month old 2022 f250 platinum. Interior map lights started just working every now and then. No illumination on the overhead console buttons except aux switches and back sliding glass when the issue is happening. Dealer has no idea whats going on with it. Any suggestions? It sounds like a loose connection. Take it to a competent dealer. Good luck and let us know the cause once it gets fixed. Edited October 25, 2022 by Monoman Quote Link to comment Share on other sites More sharing options...
