Mower Man Posted August 13, 2007 Share Posted August 13, 2007 Has Ford made any announcements about the wheelbase options for the 2009 F-150? I would like to see the return of an 8 ft. box on a 139 inch wheelbase. Quote Link to comment Share on other sites More sharing options...
rmc523 Posted August 13, 2007 Share Posted August 13, 2007 Has Ford made any announcements about the wheelbase options for the 2009 F-150? I would like to see the return of an 8 ft. box on a 139 inch wheelbase. I would assume the options are about the same as currently offered. Quote Link to comment Share on other sites More sharing options...
02SilverStroke Posted September 5, 2007 Share Posted September 5, 2007 I would assume the options are about the same as currently offered. Isn't the 2009 just a "refreshing" of the 2007-2008's? From what I've read, the 2009 will have the three bar grille, so it should bear a strong resemblance to the Expedition. If it's just a "refreshing", then there probably won't be any changes to the wheelbases and/or cab styles. Quote Link to comment Share on other sites More sharing options...
DearbornDerek Posted September 5, 2007 Share Posted September 5, 2007 Isn't the 2009 just a "refreshing" of the 2007-2008's? From what I've read, the 2009 will have the three bar grille, so it should bear a strong resemblance to the Expedition. If it's just a "refreshing", then there probably won't be any changes to the wheelbases and/or cab styles. Crew cabs are getting an extra 6" added to the cab (and wheelbase). There is going to be over 1600 parts changes to the 09...I don't think I'd call that a refresh. It is getting a variant of the three bar...while it might look similar to an Expy at a distance, up close it's not even close. Quote Link to comment Share on other sites More sharing options...
controller Posted September 9, 2007 Share Posted September 9, 2007 Crew cabs are getting an extra 6" added to the cab (and wheelbase). There is going to be over 1600 parts changes to the 09...I don't think I'd call that a refresh. It is getting a variant of the three bar...while it might look similar to an Expy at a distance, up close it's not even close. Will the SCabs get bigger like the Tundra and Ram? I like the current size of the SCrew, but may go with SCab since I think the SCrew will be too big. Quote Link to comment Share on other sites More sharing options...
DearbornDerek Posted September 9, 2007 Share Posted September 9, 2007 Scab stays the same. Quote Link to comment Share on other sites More sharing options...
F150 Man Posted September 14, 2007 Share Posted September 14, 2007 It would be a real trick to put an 8' box on a 139" truck (crew cab with 5.5' box). Today's regular cab with an 8' is 145". While it might be possible, it would look very strange with all the overhang pass the rear wheels. Current wheelbases: Regular cab 6.5 box = 126" Regualr cab 8' box = 145" Supercab 5.5' box = 133" Subercab 6.5' box = 145" Supercab 8' box = 163" (heavy duty only) Crewcab 5.5' box = 139" Crewcab 6.5' box = 151" Crewcabs grow 6" for 2009 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 15, 2007 Share Posted September 15, 2007 (edited) Will the SCabs get bigger like the Tundra and Ram? I like the current size of the SCrew, but may go with SCab since I think the SCrew will be too big. I read somewhere that the new largest cab available (unsure of the name) will be larger than Dodge's MegaCab and Toyota's whatever it's called (CrewMax??). Edited September 15, 2007 by rmc523 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 15, 2007 Share Posted September 15, 2007 (edited) Isn't the 2009 just a "refreshing" of the 2007-2008's? From what I've read, the 2009 will have the three bar grille, so it should bear a strong resemblance to the Expedition. If it's just a "refreshing", then there probably won't be any changes to the wheelbases and/or cab styles. IMO this would make a great looking F-150. Maybe square the headlights a bit more, like Expedition. Edited September 15, 2007 by rmc523 Quote Link to comment Share on other sites More sharing options...
rmc523 Posted September 15, 2007 Share Posted September 15, 2007 (edited) Isn't the 2009 just a "refreshing" of the 2007-2008's? From what I've read, the 2009 will have the three bar grille, so it should bear a strong resemblance to the Expedition. If it's just a "refreshing", then there probably won't be any changes to the wheelbases and/or cab styles. More pictures here.... http://news.windingroad.com/body-stylesmar...otypes-spotted/ Edited September 15, 2007 by rmc523 Quote Link to comment Share on other sites More sharing options...
