bbob Posted June 23, 2006 Share Posted June 23, 2006 Just a question about towing with a F150. I have a 2003 F150 5.4 litre and am debating about 2006 with the 4.6 instead. I noticed the towing capacity is greatly increased in the new 4.6 compared to the older one (2003 and below) Is it necesary to go with a 5.4 litre or should I get a 4.6? The towing capacity seems to only be 300lbs difference. 6900 vs 7200. Let me Know!!!! Quote Link to comment Share on other sites More sharing options...
J-150 Posted June 23, 2006 Share Posted June 23, 2006 the added weight in the truck sucks up all of the HP increases. If you will be towing anything more than 2000#, you need the 5.4 Quote Link to comment Share on other sites More sharing options...
jsnsan Posted June 24, 2006 Share Posted June 24, 2006 well if your worried about towing than I can tell you this, the 4.6L will dissapoint you. when towing you want to look at torq and horsepower obviously, but also gear ratio and what truck style you want (regular cab, supercrew, etc.). where the 4.6 is still based on alot of older tech. the 5.4 is a whole new monster. it has charge motion control valves in the intake runners to speed up air velocity at low RPMs which means more low end power, it also has variable cam timing which gives you optimum performance at all RPMs depending on the load on the engine. all this adds up to 80% of your torq at a mere 1,000 RPMs!!!! I personally own a 2004 F-150 FX4 SuperCrew 4X4 5.4L, I tow a 26 foot travel trailer with a Honda Forman fourwheeler in the bed, and this thing will pull just fine, granted your not going to break any speed records but you'll pull pretty much what ever you want. oh yeah, I've never NEVER had a problem with this truck either not one single thing :yup: Quote Link to comment Share on other sites More sharing options...
DearbornDerek Posted June 26, 2006 Share Posted June 26, 2006 Isn't the towing capacity on the 2007 F-150 with the 5.4 going up to 10,500 lbs, or is that the 250/350? Yes it's the 150. BSG withdrawl yet? Quote Link to comment Share on other sites More sharing options...
Hydro Posted July 1, 2006 Share Posted July 1, 2006 My 2003 5.4 Supercrew has a rating of #8,300. No 4.6L would be in the ballpark. Quote Link to comment Share on other sites More sharing options...
