7Mary3 Posted March 2, 2011 Share Posted March 2, 2011 Got a question, specifically about the 6R140 Torqshift, but applicable to the other Ford 6 speeds. The question is why don't they have a 1:1 ratio in them anymore? I figure it must have something to do with the use of the Lapelletier geartrain, because the GM 6L80 and 6L90 also use that design, and they don't have a 1:1 either. I always liked the idea of a 1:1 for towing, because I assumed it was stronger. I know that the Lapelletier is a less complex design than the old 4 speed automatics that used Simpson geartrains. Quote Link to comment Share on other sites More sharing options...
Summer Cruiser Posted March 2, 2011 Share Posted March 2, 2011 That's a really good question. Perhaps the durability in the new 6-speeds is better due to inherantly having to shift more, so when towing it uses the first overdrive in steady driving for better fueleconomy, shifting down in higher-burden situations. But that's just my speculation. Quote Link to comment Share on other sites More sharing options...
jpd80 Posted March 2, 2011 Share Posted March 2, 2011 (edited) Got a question, specifically about the 6R140 Torqshift, but applicable to the other Ford 6 speeds. The question is why don't they have a 1:1 ratio in them anymore? I figure it must have something to do with the use of the Lapelletier geartrain, because the GM 6L80 and 6L90 also use that design, and they don't have a 1:1 either. I always liked the idea of a 1:1 for towing, because I assumed it was stronger. I know that the Lapelletier is a less complex design than the old 4 speed automatics that used Simpson geartrains. Yes the Lepelletier gear set allows more gear ratios with less moving parts but also means no more 1:1 gear ratio. An interesting aside was the development of an Australian 6-speed auto that actually loads in to the previous 4-speed auto case - great grandson of the Borg Warner 35 transmission but now sadly owned by the Koreans. Edited March 2, 2011 by jpd80 Quote Link to comment Share on other sites More sharing options...
jpd80 Posted March 2, 2011 Share Posted March 2, 2011 Got a question, specifically about the 6R140 Torqshift, but applicable to the other Ford 6 speeds. The question is why don't they have a 1:1 ratio in them anymore? I figure it must have something to do with the use of the Lapelletier geartrain, because the GM 6L80 and 6L90 also use that design, and they don't have a 1:1 either. I always liked the idea of a 1:1 for towing, because I assumed it was stronger. I know that the Lapelletier is a less complex design than the old 4 speed automatics that used Simpson geartrains. Yes the Lepelletier gear set allows more gear ratios with less moving parts. An interesting aside was the development of an Australian 6-speed auto that actually loads in to the previous 4-speed auto case - great grandson of the Borg Warner 35 transmission but now sadly owned by the Koreans. Here's a picture of ZF trans with good view of gear set. Quote Link to comment Share on other sites More sharing options...
