Is This Ford F-150 Ad a Counter Punch to the Chevy Silverado “Rock Drop” Attack?
Someone dropped the ball at Ford insuring the bed was as puncture resistant as a steel one. And no bed liners should not be the fix for an inadequately puncture resistant bed floor. The old trucks never had this issue and go back to the 70's the only way you were puncturing those galvanized steel bed floors was if you were using a drill and bit. The easy solution is to make the bed floor out of the same material as is used in the aluminium M1101 trailers on their bed floors. You can hardly dent that stuff with a sledge hammer let alone puncture it, and the weight penalty would be less than a spray in bed liner. That is the easiest solution for a proper fix. Then Ford can add Mil Spec truck bed to the advertising tag line.
