Lefty205
Periodic strong gasoline smell after startup
Periodically my 2016 MKX will very strongly smell of raw gas right after starting, backing out of the garage & continuing for a time after driving away. The dealer has been unable to identify the cause, although by "tightening things up" in the engine compartment it will be ok for a while.
Does this sound familiar? Has the cause been found?  Great car other than this annoyance!
You're smelling it in the cabin? Several possibilities to check, In order.
Check for missing/broken hardware on exhaust manifolds, cats, or Y pipe. Check manifolds for cracks. Soot around any pre-cat connection is also an indicator of leakage.
Loose spark plugs.
Fuel leaks from rail/injectors and EVAP system.
Check for missing/damaged grommets, air vents and decklid seal, just as they would for CO issues in Explorer.
Make sure HVAC is at latest software level- won't solve issue, but may mitigate it some.
Yes, odor in the cabin. Thank you-- great checklist, hope to find a cause.
