ice-capades Posted July 14, 2023 Share Posted July 14, 2023 (edited) 2024 F-150 Platinum Will Have Lettering on Hood https://fordauthority.com/2023/07/2024-ford-f-150-platinum-will-have-lettering-on-hood/ The 2024 Ford F-150 is set to bring forth a refresh for the perennially best-selling pickup, which means that we can expect to see revised styling on the outside, as well as a few changes inside the cabin as well. Ford Authority has reported extensively on the refreshed 2024 Ford F-150 over the past few months, while also spotting a host of prototypes out driving around, covered in varying levels of camouflage. Now, sources familiar with the matter have revealed yet another detail about the 2024 Ford F-150 – specifically, the higher-end Platinum trim. The 2024 Ford F-150 Platinum will have its name spelled out on the hood, it turns out, which is a big change from the current model. However, this look isn’t totally new to the F-150 lineup, as the range-topping Limited currently features this same type of letting across the hood, as can be seen in the picture above. Edited July 14, 2023 by ice-capades Additional Content 1 Quote Link to comment Share on other sites More sharing options...
ice-capades Posted July 14, 2023 Author Share Posted July 14, 2023 I just don't know what Ford designers are doing these days. They create different grille treatments for every F-150 model level but that's not enough. Let's see what else we can pull out of the parts bin... okay, let's slap the model designation on the hood. 1 Quote Link to comment Share on other sites More sharing options...
fuzzymoomoo Posted July 14, 2023 Share Posted July 14, 2023 3 minutes ago, ice-capades said: I just don't know what Ford designers are doing these days. They create different grille treatments for every F-150 model level but that's not enough. Let's see what else we can pull out of the parts bin... okay, let's slap the model designation on the hood. I noticed in the parking lot the other day there’s two completely different hoods depending on which grille you opt for. One has a flat leading edge, one has a cutout to accommodate the grille as seen in the top of the page. 1 Quote Link to comment Share on other sites More sharing options...
