Casey187 Posted July 31, 2024 Share Posted July 31, 2024 I’m currently looking at a car on fb marketplace and the owner claims that the car will only go up to 10 mph and has slight coolant and oil leaks and that the transmission is good. I’m hoping to buy the vehicle but want to know if I’d be better off finding something different or if it’s an easy fix. Thanks ahead of time! Quote Link to comment Share on other sites More sharing options...
akirby Posted July 31, 2024 Share Posted July 31, 2024 Absolutely no way to tell. Could be a valve cover gasket, coolant reservoir and a throttle body or a new engine and transmission. Quote Link to comment Share on other sites More sharing options...
Casey187 Posted August 1, 2024 Author Share Posted August 1, 2024 7 hours ago, akirby said: Absolutely no way to tell. Could be a valve cover gasket, coolant reservoir and a throttle body or a new engine and transmission. He did say that the transmission was rebuilt but insists that it is good Quote Link to comment Share on other sites More sharing options...
akirby Posted August 1, 2024 Share Posted August 1, 2024 8 hours ago, Casey187 said: He did say that the transmission was rebuilt but insists that it is good Unless you have a mechanic do a thorough evaluation (and even then you can’t be 100% sure) I would assume you have to replace the engine and tranny very soon and factor that into your negotiations. Quote Link to comment Share on other sites More sharing options...
Casey187 Posted August 1, 2024 Author Share Posted August 1, 2024 7 minutes ago, akirby said: Unless you have a mechanic do a thorough evaluation (and even then you can’t be 100% sure) I would assume you have to replace the engine and tranny very soon and factor that into your negotiations. Ok thank you for the advice Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted August 1, 2024 Share Posted August 1, 2024 (edited) 18 hours ago, Casey187 said: I’m currently looking at a car on fb marketplace and the owner claims that the car will only go up to 10 mph and has slight coolant and oil leaks and that the transmission is good. I’m hoping to buy the vehicle but want to know if I’d be better off finding something different or if it’s an easy fix. Thanks ahead of time! Hi Casey187. It certainly does not sound like an "easy fix". However, there is no way to offer an accurate answer via blind Internet guesses, as akirby stated above. As just one example: It would be difficult to determine if the transmission is good, when the vehicle can "only go up to 10 mph". Unfortunately, the problem/problems could be any of a 100+ things, or any combination of those same things. The best way to possibly get some sort of answer would be to have a professional tech/mechanic/shop do a full in inspection. But even the ability of a good shop to inspect and offer a verdict would be limited. My guess is any competent shop will likely tell you to find something different, unless you want a long term project car. Let us know how you make out and good luck. Edited August 1, 2024 by bbf2530 Quote Link to comment Share on other sites More sharing options...
