Sudden Intelligent Access and other Electronis Issues
Hi everyone, new member here.
    In October bought a used 2023 Corsair Reserve with a 201A package & a Pano roof, only 0005079 km. It worked fine until Tuesday Nov 26 when suddenly the intelligent access works only on the driver's door. The Intelligent Access IS enabled in settings. Also, when I get in to start it, the indicator light on the Park shift key is flashing, when started the instrument cluster displays what it wants to not as I had it set, when I turn the engine OFF, the touch screen displays the "turning off to conserve battery, please press the ignition to turn off" notification.
   Any ideas why this started happening? I have searched and gone through the owners manual to no avail.
Thanks.
Thanks.
HI 427 CobraJet and welcome to the Blue Oval Forums. Possibly/probably a failing battery, as akirby stated. However, there are other possibilities. No matter what the cause, the best course of action, since your 2023 Corsair is still within warranty, would be to call and schedule a service appointment with your Lincoln Dealership.
In this way, they can properly diagnose and correct the issue under warranty.
EDIT- Just saw your reply on another forum stating that you spoke with the Service Advisor and scheduled an appointment for Thursday. Good luck!
Keep us updated and good luck.
Edited by bbf2530
On 11/28/2024 at 4:30 PM, akirby said:
Weak battery 98% of the time.
UPDATE: -took it in on Thursday (Dec 05). They tested the battery & found it to be low so they charged it. As it held the charge & passed the load test they wouldn't replace it. When the electronics tech. came to test it, it still had the same problems. I had to leave it. Late Friday they advised it was not working and needed a new battery but no time to do it all so I had to leave it for the weekend. Picked it up yesterday morning & reviewed the 4 page work order. They replaced the battery, traced an issue to some wiring damage under the Rt Ft seat and repaired it. It also got sent out for an exterior polish & buff. So far so it's behaving.
