2008 rear drums
Steeltoes
  • 3 weeks later...
The pre 2005 Escapes had only rear drums as well. The switch to rear discs had hardly any impact on stopping distance.
Good point. However, whatever changes Ford has applied to the 2008 model has resulted in major diminution of braking performance compared to the original 2001 Escape.
Car and Driver's tests show a 33 ft. increase (70 mi./h - 0) in the 2008 compared to the 2001 model. Consumer Reports also noted subpar braking performance in its test of the '08 Escape.
Edited by aneekr
Thats is a very biased article to start with, I question the results and take them with a grain of salt. No mention of:
- Vehicle weight differences
- Tires
- AWD vs 4WD systems
Just to name the obvious. All these things have an effect on braking distance.
After rereading that article, the author is more interested in trying to look cool than put out an informative piece.
Edited by atomaro
  • 2 months later...
I would prefer disc brakes, but to be quite honest, about 70% of the braking comes from the front wheels, so the rear drums are not as critical as you might think.
The hybrids still have rear discs. Possibly because the fronts aren't used much due to the regen, which leaves the rears to do most of the "real" braking (as needed). Because of this, on a hybrid, the rear pads wear faster, and need replacing more often, than the fronts.
