joyride Posted March 9, 2011 Share Posted March 9, 2011 Could the power liftgate height on EDGE be adjusted? I have a low ceiling in my garage, I am wondering if this is adjustable. Quote Link to comment Share on other sites More sharing options...
NickF1011 Posted March 9, 2011 Share Posted March 9, 2011 I do not believe so. If it is, it would probably require a dealer visit. Quote Link to comment Share on other sites More sharing options...
joyride Posted March 10, 2011 Author Share Posted March 10, 2011 I do not believe so. If it is, it would probably require a dealer visit. Thank you for the reply, I will pay a visit to dealer and ask them if this is adjustable. Quote Link to comment Share on other sites More sharing options...
4havnfun Posted March 11, 2011 Share Posted March 11, 2011 Thank you for the reply, I will pay a visit to dealer and ask them if this is adjustable. Please post an update when you find out. I also have the same issue and am afraid to open the liftgate inside the garage. Quote Link to comment Share on other sites More sharing options...
midwestbiker Posted March 17, 2011 Share Posted March 17, 2011 (edited) I have the same issue a low garage ceiling and lower garage doors when they are open. I am able to open the rear liftgate with the garage door open (the car is pulled in - not backed in). My garage is so small I have to have the garage door open to open the hatch because I have only a few inches from my back bumper to the garage door when the door is shut - not enough room for the arc necessary to open the hatch. While outside and clear - open the back hatch and you'll see that it only raises 5 to 6 inches higher than the roof of the car. So if you have that clearance from the roof to the ceiling, you'd be fine. Take it off the power lift and manually open it when checking for clearance the first time and you'll be fine. Edited March 17, 2011 by midwestbiker Quote Link to comment Share on other sites More sharing options...
joyride Posted March 18, 2011 Author Share Posted March 18, 2011 I have the same issue a low garage ceiling and lower garage doors when they are open. I am able to open the rear liftgate with the garage door open (the car is pulled in - not backed in). My garage is so small I have to have the garage door open to open the hatch because I have only a few inches from my back bumper to the garage door when the door is shut - not enough room for the arc necessary to open the hatch. While outside and clear - open the back hatch and you'll see that it only raises 5 to 6 inches higher than the roof of the car. So if you have that clearance from the roof to the ceiling, you'd be fine. Take it off the power lift and manually open it when checking for clearance the first time and you'll be fine. I went to pick up my Edge today and asked the dealer, they don't know the answer. You did provide a good idea to check it, I will try that. Quote Link to comment Share on other sites More sharing options...
blazerdude20 Posted March 21, 2011 Share Posted March 21, 2011 idk about the edge, it works this way on the explorer, but its worth a shot. open the liftgate to where you want it to stop at. press and hold the liftgate button in the back until it beeps. that means it is set to only open that high. hope it works. Quote Link to comment Share on other sites More sharing options...
VinceL Posted January 22, 2012 Share Posted January 22, 2012 idk about the edge, it works this way on the explorer, but its worth a shot. open the liftgate to where you want it to stop at. press and hold the liftgate button in the back until it beeps. that means it is set to only open that high. hope it works. Unfortunately, that method does not work on the Edge. Tried it on my friend's 2012 Sport and all it did was make the liftgate close. Worth a try though! Quote Link to comment Share on other sites More sharing options...
