skittet150 Posted July 29, 2006 Share Posted July 29, 2006 I reciently found out that my F150 SC, 2004, had a leak in the rear of the cab. Seat was all wet. Found out it was the rear 3rd brake light mounted on the top of the cab, I think a gasket was not installed properly. Anybody else have that problem. What did you do? I heard there was a TSB on it. Quote Link to comment Share on other sites More sharing options...
J-150 Posted July 29, 2006 Share Posted July 29, 2006 I reciently found out that my F150 SC, 2004, had a leak in the rear of the cab. Seat was all wet. Found out it was the rear 3rd brake light mounted on the top of the cab, I think a gasket was not installed properly. Anybody else have that problem. What did you do? I heard there was a TSB on it. common problem your dealer will fix it Quote Link to comment Share on other sites More sharing options...
flanaganman Posted July 30, 2006 Share Posted July 30, 2006 take it in, takes all of 5 min had mine done just a few days ago the same day i found the leak its the gasket, got a new light for free its no big deal Quote Link to comment Share on other sites More sharing options...
bigbird Posted August 23, 2006 Share Posted August 23, 2006 just go to your dealer. i work at the norfolk plant. i have a 2004 also, and the same problem happen to me. they over torqued the gasket and squeezed it out between the plastic housing and the roof of the truck. they will replace and put on a new one with the right torque. good luck. Quote Link to comment Share on other sites More sharing options...
