RangerM Posted August 6, 2013 Share Posted August 6, 2013 Just curious. I'm planning to purchase an F-150 this coming weekend, and was interested to see if there is a way to tell when the truck was actually built; either by looking at the window sticker, the door jam, or elsewhere. Quote Link to comment Share on other sites More sharing options...
SoonerLS Posted August 6, 2013 Share Posted August 6, 2013 (edited) I think it's on the window sticker. There's a box labeled "Method Of Delivery" (mine says "RAIL), and there are two skinny boxes next to it; the upper is labeled "Item #" and the lower has several alphanumeric strings separated by space, and it looks like the last three sets of numbers (two digits each) is the date of manufacture. F'rinstance, mine says "11 08 12," or November 8, 2012. Or maybe that's just coincidence? If you have the truck's VIN, you can look up the window sticker here: http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin=YourVINHere Just replace YourVINHere with your truck's VIN (no spaces), like so: http://www.inventory.ford.com/services/inventory/WindowSticker.pdf?vin=1FT8W3DT6DEA55309 (I have no idea whose truck that is; I just found it via a Google search.) Edited August 6, 2013 by SoonerLS Quote Link to comment Share on other sites More sharing options...
jasonj80 Posted August 6, 2013 Share Posted August 6, 2013 It's also on the inside of the driver side door. Quote Link to comment Share on other sites More sharing options...
RangerM Posted August 6, 2013 Author Share Posted August 6, 2013 I have the window sticker, and the Method of Transp. says "CONVOY", and the location (to the right) described has a "01 03 13". January 3, 2013, I assume. If that's the case, I suppose the truck has been there for awhile. Quote Link to comment Share on other sites More sharing options...
RichardJensen Posted August 6, 2013 Share Posted August 6, 2013 the Method of Transp. says "CONVOY" Quote Link to comment Share on other sites More sharing options...
Schpark Posted August 6, 2013 Share Posted August 6, 2013 http://www.etis.ford.com/vehicleSelection.do Enter your VIN here and it will show the build date among other info. Quote Link to comment Share on other sites More sharing options...
SoonerLS Posted August 7, 2013 Share Posted August 7, 2013 I think it's on the window sticker. There's a box labeled "Method Of Delivery" (mine says "RAIL), and there are two skinny boxes next to it; the upper is labeled "Item #" and the lower has several alphanumeric strings separated by space, and it looks like the last three sets of numbers (two digits each) is the date of manufacture. F'rinstance, mine says "11 08 12," or November 8, 2012. Or maybe that's just coincidence? Maybe it is just coincidence--according to the FordEtis site linked above, my truck was built on November 18th, not November 8th. Maybe November 8th was when the VIN was assigned? The Sync update history on SyncMyRide.com also shows November 18th; I guess I'll have to check the manufacturing sticker and see what it says. Quote Link to comment Share on other sites More sharing options...
timf Posted August 7, 2013 Share Posted August 7, 2013 The date on the window sticker is the date your truck was sent to production and the window sticker was generated. The date on ETIS was the date your truck rolled off the final assembly line. There's usually about a week difference between the two dates. 3 Quote Link to comment Share on other sites More sharing options...
transitman Posted August 7, 2013 Share Posted August 7, 2013 The ETIS site uses the European style of day/month/year Every window sticker I've received from the dealer has the bottom of the page removed, where the build date is printed. Also try here, date will look something like: 1201207090116 (2012/07/09) which translates to July 9, 2012 http://www.researchmaniacs.com/Ford/TrackFactoryCarOrders.html Quote Link to comment Share on other sites More sharing options...
Pioneer Posted August 7, 2013 Share Posted August 7, 2013 Etis is terribly inaccurate for a lot of things, but it will get you close. Post the VIN and I can see if it's still the system. Quote Link to comment Share on other sites More sharing options...
RangerM Posted August 7, 2013 Author Share Posted August 7, 2013 (edited) Etis is terribly inaccurate for a lot of things, but it will get you close. Post the VIN and I can see if it's still the system. I checked ETIS, and it was close to the date that was (apparently) listed on the sticker. Here is the sticker. (Edit: Forgot to attach the sticker the first time) Webview.pdf Edited August 7, 2013 by RangerM Quote Link to comment Share on other sites More sharing options...
murphy62 Posted August 7, 2013 Share Posted August 7, 2013 The date on the sticker is the sticker creation date, in your case 01/03/13 The build date is 01/11/13. Quote Link to comment Share on other sites More sharing options...
RangerM Posted August 7, 2013 Author Share Posted August 7, 2013 (edited) The date on the sticker is the sticker creation date, in your case 01/03/13The build date is 01/11/13. Got it. Thanks. Just a thought (for anyone reading this), if that's 7-month old oil in it, should I request the dealer change it before delivery? The truck had about 20 miles on odometer after my test drive. Edited August 7, 2013 by RangerM Quote Link to comment Share on other sites More sharing options...
kenp77 Posted August 7, 2013 Share Posted August 7, 2013 Etis is terribly inaccurate for a lot of things, but it will get you close. Post the VIN and I can see if it's still the system. Pioneer: Could I get one more favor could u see if my truck was actually built on 8/6/13 and if it tells when it will be shipped 1FTFX1EFXDFD27467?? Quote Link to comment Share on other sites More sharing options...
Pioneer Posted August 8, 2013 Share Posted August 8, 2013 I checked ETIS, and it was close to the date that was (apparently) listed on the sticker. Here is the sticker. (Edit: Forgot to attach the sticker the first time) That truck was produced on January 11th, shipped the next day, and was delivered to Capital Ford on January 21st. Quote Link to comment Share on other sites More sharing options...
Pioneer Posted August 8, 2013 Share Posted August 8, 2013 Pioneer: Could I get one more favor could u see if my truck was actually built on 8/6/13 and if it tells when it will be shipped 1FTFX1EFXDFD27467?? The system hasn't updated yet on your vehicle. It was scheduled to be built yesterday. It doesn't show it was produced, but it shows awaiting shipment with an ETA at your dealer of September 6th. I would hope your ETA is moved up when the system updates. I can't see it taking a month to get to your dealer. Quote Link to comment Share on other sites More sharing options...
RangerM Posted August 8, 2013 Author Share Posted August 8, 2013 That truck was produced on January 11th, shipped the next day, and was delivered to Capital Ford on January 21st. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
kenp77 Posted August 8, 2013 Share Posted August 8, 2013 The system hasn't updated yet on your vehicle. It was scheduled to be built yesterday. It doesn't show it was produced, but it shows awaiting shipment with an ETA at your dealer of September 6th. I would hope your ETA is moved up when the system updates. I can't see it taking a month to get to your dealer. Pioneer: Thanx much guess it is just a waiting game now, I am on the west coast but am sure it won't take a month to get here, ford may notify my dealer when it is shipped not sure though... Quote Link to comment Share on other sites More sharing options...
wellandford Posted September 23, 2014 Share Posted September 23, 2014 I believe cyberdman can assist. Quote Link to comment Share on other sites More sharing options...
