2013 escape engine will not turn over
SENOJ
hi there
car has been sat for 10 days in temps of below -15 c
went to start it today & engine will not turn,maybe thought I heard a clicking sound , could this be a solenoid prob ?
lights ,fan,radio all working
no block heater used yet
is it just a flat battery,or worse a frozen one
plan is to plug in block heater for 3 hours tomorrow,then try a jump start.
battery was fully charged so bit surprised it will not start engine
any thoughts on this or shall I just get roadside assistance to come out & get it started.
all help greatly appreciated
What engine do you have? Do you have the power Pano roof?? Please see TSB below. It says 2 weeks or longer, but the sub-zero temps could shorten that time frame.
TSB 13-03-04 – 2013 Escape – Discharged Battery – Vehicle Not Driven For Two Weeks Or Longer
Some 2013 Escape vehicles built on 8/28/2012 and through 12/5/2012 and equipped with a roof opening panel
may exhibit a discharged battery condition only after the vehicle has not been driven for two weeks or longer.
Follow the service procedure steps in this TSB to correct the condition by replacing the roof opening panel motor
shade and roof opening panel motor sliding front panel. Refer to the workshop manual, section 501-17.
thanks for the reply
on reflection I noticed back in the summer & fall that if I put the accessories on like the radio for more than 10 mins the battery protection would kick in & shut down the car so maybe this was coming for a while
spoke to my dealer service guy this morning & told him about the t,s,b, but he wasn't too supportive of that,& he said that they have had lots of probs after this cold snap as if its all perfectly normal.
asked if frozen would it power the lights etc & he said yes,advised me to start car once a week !!!!,not seen this in any adverts though !!!!
bad side is it looks like I will have to fight fords for a new battery or pay $150.00 for a new one.
disappointed to say the least that it will not start
plugged in the block heater 2 hours ago so that mite help
waiting for roadside to come out
flat battery after all,it was down to 9 volts so alls well
going to go for a spin in the snow
going to turn it over more often in the cold
never had this prob before but wise to it now
Edited by SENOJ
With these record cold temps, I'd suggest buying a Deltran Battery Tender. If the car sits, simply leave it plugged in. It will maintain but no charge a battery.
http://www.amazon.com/Battery-Tender-021-0156-Charger-Model/dp/B000NCOKQK/ref=sr_1_9?ie=UTF8&qid=1389279457&sr=8-9&keywords=battery+tender
All my batteries use them. Motorcycle, tractor. Simply starting it once in a while does more harm than good. It caused condensation inside mechanical components that isn't burnt off unless the motor runs long enough. It wates gas and draws more from the battery than it returnsd.
That year doesn't have the roof indicated in the TSB. Odd that a moonroof would cause battery draw when not being operated.
In the OP, it sat for ten days.
Yes, but it has been 20 years since it's been this cold so I thought it might be a factor. And the OP says its a 2013. Mine is a 2013 and it falls within that range. You don't go by the year, you go by the build date. Last time I checked many 2013s were built within the affected dates. But here is the TSB anyway.
Edited by Escapism
I was refering to the 2007 Milan. Ten days at subfreezing weather could kill a marginal battery. Add to that the current draw of all the newer elctronics and it's easy to see the problem. I still never thought a sun/moon roof would have a current draw when not being used.
Roger that. Yeah, same goes for me.
