Giotal
2019 fusion 2.0
Hello have a 2019 fusion with 38xxx miles. Just had the check engine light come on and the code is p2450. Anyone can help guide me as to what it can be . Thanks!
Hi Giotal. Look here: https://www.dtcdecode.com/Ford/P2450
It is an evaporative emissions code. "Evap system switching valve performance/stuck open". While it sounds like it would be a slam dunk to replace the valve, there are other component failures in the system that can trigger that code. You need to have it diagnosed.
This doesn't look like a serious problem. If you are about to fix it by yourself, try to start with searching "fusion p2450" on youtube. Sometimes you just need to check all the pipings, sometimes to clean or replace the valve itself. But overall, this issue is quite common among various cars - no worries.
