jmac0408 Posted May 12, 2020 Share Posted May 12, 2020 I have a 2014 Focus SE 5 Dr. which has developed a leaking MoonRoof. It is covered with an Extended Warranty. Will this issue be covered under that warranty? Thanks. Quote Link to comment Share on other sites More sharing options...
bbf2530 Posted May 12, 2020 Share Posted May 12, 2020 1 hour ago, jmac0408 said: I have a 2014 Focus SE 5 Dr. which has developed a leaking MoonRoof. It is covered with an Extended Warranty. Will this issue be covered under that warranty? Thanks. Hi jmac. We would need more information.There are various levels of FordCare/ESP Ford Factory Plans and also third party plans. Some only cover the powertrain, while the top tier plans would cover a sunroof leak. Therefore, it will depend on which Extended Warranty plan you have. If you post back with which Plan you have, we should be able to give you an answer. Good luck. Quote Link to comment Share on other sites More sharing options...
jmac0408 Posted May 13, 2020 Author Share Posted May 13, 2020 It's the PREMIUM CARE 36/60 (KM's) !! Quote Link to comment Share on other sites More sharing options...
akirby Posted May 13, 2020 Share Posted May 13, 2020 Go here https://fordprotect.ford.com/ Find your plan and it will list what is covered and not covered. Quote Link to comment Share on other sites More sharing options...
jmac0408 Posted May 13, 2020 Author Share Posted May 13, 2020 Thanks, "akirby" !! Much appreciated. Have a good one today! John A. Quote Link to comment Share on other sites More sharing options...
