powerboatr 1 Posted April 5 my truck did not come with the 36o camera system, but in the front grill hiding behind the big oval is a camera wire. is it possible to add the blue oval plate with the camera or will the system need a reboot at ford to recognize the front camera? thanks Share this post Link to post Share on other sites
powerboatr 1 Posted April 8 i think maybe i left something out, 92 views all my trucks before had many extra wires , and all of them were capped off, to prevent corrosion or water damage of said connector or wiring this camera connection fitting is un capped and looks like it should be plugged into something. so my thinking is if i acquire the the correct camera and install it with a new emblem with washer, will the head unit see it and pick it up or would it take ford to turn it on? i would like to have the eye ball up there as this beast hard to tell just how close i can get to the wall, i have a swim noodle now as the "STOP NOW" indicator Share this post Link to post Share on other sites
ScottK1 16 Posted April 8 I don't know about the camera, but if you're parking up to a wall, look into rubber dock bumpers as a more permanent solution to the noodle. I would think you could use FORscan to make any software changes needed to activate the camera. Maybe ask on forums where more customization is done, like here: https://www.ford-trucks.com/forums/forum279 Share this post Link to post Share on other sites
powerboatr 1 Posted April 8 talked to my service folks this afternoon during a warranty issue repair. i can have the front camera put on that is part of the 360 camera system........and tell the brains to see it. but it is not cheap, and once i go down that road i might as well pay to put in the whole 360 protrailer system. so i think 5k is a bit steep, so next solution will be sought thanks all Share this post Link to post Share on other sites
Michael Lappy 3 Posted April 9 You could always try to find someone that doesn’t want it and swap parts out 1 powerboatr reacted to this Share this post Link to post Share on other sites
twintornados 2,327 Posted April 10 10 hours ago, Michael Lappy said: You could always try to find someone that doesn’t want it a junk yard and swap parts out fixed Share this post Link to post Share on other sites
