Barcuss Posted September 28, 2022 Share Posted September 28, 2022 MY mother has a 16 Escape Ecoboost that has just stared a puff of smoke when the car is first started up, it goes away after just a couple of seconds. It comes out of both tail pipes. Following behind her it does not smoke at all while driving. Any help or thoughts would be greatly appreciated. I believe it is the 1.6 Ecoboost Quote Link to comment Share on other sites More sharing options...
akirby Posted September 28, 2022 Share Posted September 28, 2022 Could be normal especially in humid areas. Check the coolant level. If it’s low have the dealer check the compression. It may be covered by an extended warranty. If level is full and no other issues it’s probably ok. Quote Link to comment Share on other sites More sharing options...
Barcuss Posted September 28, 2022 Author Share Posted September 28, 2022 First off, GO DAWGS.... She just started it for me to see again and its kinda like blue smoke coming out of the tail pipes but only for a few seconds. Engine sounds normal and the vehicle drives normal. 1 Quote Link to comment Share on other sites More sharing options...
92merc Posted September 28, 2022 Share Posted September 28, 2022 It could be the coolant intrusion issue. Have your dealer check it. If it is that, the block cracked and coolant is getting into the cylinders. Quote Link to comment Share on other sites More sharing options...
akirby Posted September 28, 2022 Share Posted September 28, 2022 2 hours ago, Barcuss said: First off, GO DAWGS.... She just started it for me to see again and its kinda like blue smoke coming out of the tail pipes but only for a few seconds. Engine sounds normal and the vehicle drives normal. Blue smoke is oil. Might be a ring problem. Quote Link to comment Share on other sites More sharing options...
silvrsvt Posted September 29, 2022 Share Posted September 29, 2022 White smoke out of DI turbo charged engines is “normal” when it is cold out. Quote Link to comment Share on other sites More sharing options...
